Autor Tema: kodiranje podizanja i spustanja stakla daljincem  (Pročitano 5086 puta)
Van mreže faki85
  • Poruke: 543
  • Lokacija: beograd
« poslato: Septembar 13, 2010, 11:26:58 pre podne »
 Default  How-To: Keyfob Remote Windows Up/Down.
You will need a VDS-PRO with serial cable, that is all.
-Boot the computer into real mode dos (i.e. safe mode with command prompt) or boot from a disk containing VDS-PRO.
-Run the vag.bat file in the VDS folder
-Press ESC to cancel the auto-connect
-Connect your cable (it should not be connected before this)
-Connect to the CCM (type 46)
-Login with code 19283 (type 11)
-Look up and write down your existing memory values (type 26 and enter the addresses and values listed below)
-Change the values (type 27 and enter the addresses and values listed below)
-Close the connection (type 06)
-Test that things work as they should!
Note: The "old value" for your CCM may be different than listed below.
Codings:
CCM 1J0 959 799 AH (Any Index) and 1J0 959 799 S 03B
Memory Address / old value / new value
04283 / 8 / 2
04289 / 8 / 2
08628 / 242 / 246 driver side front window
12724 / 250 / 254 passenger side front window
16820 / 250 / 254 driver side rear window
20916 / 242 / 246 passenger side rear window
CCM 1J0 959 799 J 00E
04291 / 8 / 2
04296 / 8 / 2
CCM 1C0 959 799 A (Any Index) and 1C0 959 799 B (Any Index) for Variant/Wagon
04361 / 75 / 67
04362 / 75 / 67
04363 / 75 / 67
CCM 1C0 959 799 A (any index) and 1C0 959 799 B (any index) for Limousine/Sedan
04361 / 74 / 66
04362 / 74 / 66
04363 / 74 / 66
butabilni dos sa vds-pro  http://rapidshare.com/files/279158760/VDS-PRO_DOS6.22.iso
« Poslednja izmena: Septembar 13, 2010, 11:29:35 pre podne od strane faki85 »
Odg: kodiranje podizanja i spustanja stakla daljincem
« Odgovor #1 poslato: Septembar 13, 2010, 07:00:00 posle podne »
 :huh: faki  blink sta ti je  :huh:
O cem to ti? Kakav butabilni dos te snas'o? I kad da ga zakacis na auto, Gde ces da nadjes laptop sa SERIAL konekcijom? Muzej?
Danas ti treba kabAl koji izgleda ovako:
Za njega ovako izgleda software i mnoooogo je jednostavan za rukovanje . . . Bez boot DOS, old memory value, new value, olovke, papira . . .
Andrija
« Odgovor #2 poslato: Septembar 13, 2010, 07:07:39 posle podne »
Sad sam krenuo misem da kliknem na Auto-Scan  lollol
« Odgovor #3 poslato: Septembar 13, 2010, 07:12:40 posle podne »
 lollol lollol lollol
Caka vredi svakog evra sto sam platio  biggrin
evo me i na globalnoj mapi  biggrin
Nick krvolok
http://www.batchgeo.com/map/06e7d2d0c038e31b257a422024919cb2
Van mreže faki85
  • Poruke: 543
  • Lokacija: beograd
« Odgovor #4 poslato: Septembar 13, 2010, 07:40:50 posle podne »
imam takav usb kabal i vcds ali sa njim ne moze da se kodira daljinsko otvaranje prozora
sa serijskim kablom moze 100% ljudi su kodirali
ne znam za taj tvoj kabal da li moze ali moj ne moze
Andrija
« Odgovor #5 poslato: Septembar 13, 2010, 07:46:23 posle podne »
Vidi, broj tel....  biggrin Sad cemo da te cimamo na mob.  lollol
« Odgovor #6 poslato: Septembar 13, 2010, 07:52:18 posle podne »
ae cim cim  biggrin
Skini zadnju verziju vcds 10.nesto
idi na 09 - cent. elect. ili 46 - Central Conv. pa trazi, a mozes i manuelno za svaka vrata pojedinacno...
Ne znam zasto bi tvoj auto koji je CAN moga da se programira samo sa serial kablom, koji se inace povlaci iz prodaje, cak i ako hoces da ga kupis moras da narucis i cekas, a komp i da ne pominjem, jer zadnji lapentopen sa serijal uticnicom je bio pentium3, znaci spor do bola, jedino preostaje da dovuces kuciste, monitor, misa i tastaturu u garazu ili pred kucu pa ljuljaj mile . . .
« Poslednja izmena: Septembar 13, 2010, 07:59:57 posle podne od strane pimbe »
Van mreže faki85
  • Poruke: 543
  • Lokacija: beograd
« Odgovor #7 poslato: Septembar 13, 2010, 07:59:32 posle podne »
fora je u tome sto nece nikako da udje u centralnu elektroniku, izbaci me
« Odgovor #8 poslato: Septembar 13, 2010, 08:02:34 posle podne »
jel ti original kabal? ako nije nemoj da se zeznas pa da updateujes jer ce ti zakljucati dongle...
Prvo skini novu verziju, pa uninstal staru, pa onda instaliraj novu, mozes i onaj vcds lite da probas...
Van mreže faki85
  • Poruke: 543
  • Lokacija: beograd
« Odgovor #9 poslato: Septembar 13, 2010, 08:07:19 posle podne »
ma gde original, 9.08 je softver
imam i 10.06 ali nece ni sa njim da udje u central elektronics
znam da ne smem da ga updatujem
mozda fush kablovi ne mogu da odrade sve
« Odgovor #10 poslato: Septembar 13, 2010, 08:08:10 posle podne »
Jel ti ovakva nalepnica (ili slicna) na kablu / dongle-u
evo link za najnoviji vcds i vcds lite
http://www.ross-tech.com/vcds/download/
moguce da fush kabal ne moze, zato probaj ovaj lite
« Odgovor #11 poslato: Septembar 13, 2010, 08:11:11 posle podne »
A mislim da ima i caka kako da ga programiras uz pomoc dugmadi za prozore na samom autu bez diagnostike, mrzi me sad da izlazim do kola da uzmem manual, jer sam siguran da ima procedura za recovery a zbog menjanja tj nakon menjanja akumulatora...
Van mreže faki85
  • Poruke: 543
  • Lokacija: beograd
« Odgovor #12 poslato: Septembar 13, 2010, 08:17:37 posle podne »
« Odgovor #13 poslato: Septembar 13, 2010, 08:21:43 posle podne »
ae napravi screenshot kad ti odbije central electric pa okaci.
I jesi li probao kroz central convinience?
Van mreže faki85
  • Poruke: 543
  • Lokacija: beograd
« Odgovor #14 poslato: Septembar 13, 2010, 08:26:55 posle podne »
tu ulazi ali ima za posesavanje samo neke gluposti
auto zakljucavanje posle 15 km\h
da ti se cuje sirena kada zakljucas
i jos neke gluposti
mislim da ima 8 stavki nista vise
« Odgovor #15 poslato: Septembar 13, 2010, 09:24:58 posle podne »
e kad udjes u taj screen onda saltas pomocu srelica dole/ gore, izlazis na esc...
ae probaj pa javi
