Autor Tema: passat b8 2.0tdi problem  (Pročitano 3281 puta)
Van mreže Night King
  • Poruke: 135
  • Auto: Passat b6 2.0tdi
« poslato: Novembar 02, 2024, 12:33:20 posle podne »
Pozdrav upalila mi se check engine lampica na displeju mi je izaslo obavestenje dpf owners manual i zuti uzvicnik.Odradio sam diagnostiku izbacio je dve greske
Saturday,02,November,2024,10:51:43:00009
VCDS Version: Release 24.7.0 Running on Windows 10 x64
www.Ross-Tech.com
                Address 01: Engine       Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 906 026 AS    HW: 04L 907 309 R
  Component and/or Version: R4 2,0L EDC   H21 1147
           Software Coding: 0119001203441D083000
            Work Shop Code: WSC 00028 028 00028
              ASAM Dataset: EV_ECM20TDI01104L906026AS 001006 (VW48)
                       ROD: EV_ECM20TDI01104L906026AS.rod
                      VCID: 7BF542EBF2E5694E96-802E
2 Faults Found:
12002 - Particulate Filter; Differential Pressure Sensor
          P2453 00 [11101101] - Implausible Signal
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 291348 km
                    Date: 2024.11.01
                    Time: 17:27:37
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 96 °C
                    Intake air temperature: 70 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 12.660 V
                    Unlearning counter according OBD: 40
                    Particle filter: air pressure sensor 1 bank 1: raw value: 240 hPa
                    Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 40 hPa
                    Par.fil: diff.pr.sens.1 bank 1: offset: 122 hPa
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 200 hPa
                    Outside temperature sensor 1: B1: raw value: 14.0 °C
                    Particle filter: soot mass measured: 15.35 g
                    Particle filter: soot mass calculated: 18.90 g
5158 - Particulate Filter; Differential Pressure Sensor
          P2456 00 [00100000] - Intermittent
          Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 1 1 0 0 0
Odg: passat b8 2.0tdi problem
« Odgovor #1 poslato: Novembar 02, 2024, 04:11:57 posle podne »
Zacepljen DPF
  • Poruke: 135
« Odgovor #2 poslato: Novembar 02, 2024, 05:08:20 posle podne »
dpf je opran i vracen na auto.
« Odgovor #3 poslato: Novembar 05, 2024, 08:42:15 pre podne »
Ako je dpf opran i vracen na auto stavis novi senzor i vratis vrijednosti dpf-a dijagnostikom.
  • Poruke: 135
« Odgovor #4 poslato: Novembar 05, 2024, 10:30:57 pre podne »
Ok hvala.
