Autor Tema: Audi A4 2009 problem sa ABS i rucnom, gde li je problem?  (Pročitano 7027 puta)
Van mreže talenat
  • Poruke: 91
« poslato: Jun 09, 2021, 01:48:12 pre podne »
Drugari zadnjih mesec i po mi se greje zadnji desni tocak, zamenili su mi nove plocice na svim tockovima.
I posle zamen taj tocak greje i skripi posle duze voznje, od pre dva dana se pojavio veci problem nadam se da ce mi neko
moci vise reci u problemu sta raditi i kako srediti isti.
Sada u toku voznje upali ABS lapmicu i auto kao da se sam zakoci.
Pritisak u kocnicama po paljenju auta je 2.2Bar, po pritiskanju pedela kocnice je 25-35bar. Ali posle pustanja kocnice pritisak nije vratio na pocetnu vrednost 2bara!?
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AK    HW: 8K0 907 379 AK
   Component: ESP8 front    H04 0070
   Revision: --------    Serial number: --------------
   Coding: 160504
   Shop #: WSC 02391 823 56573
   VCID: 0233B33D9D02B79BD5-8056
2 Faults Found:
01435 - Brake Pressure Sensor 1 (G201)
            008 - Implausible Signal - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10101000
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 188
                    Mileage: 381541 km
                    Time Indication: 0
                    Date: 2021.06.07
                    Time: 17:46:19
             Freeze Frame:
                    Hex Value: 0x4400
                    Hex Value: 0x4006
                    Hex Value: 0x1236
                    Hex Value: 0x31AF
                    Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 188
                    Mileage: 381541 km
                    Time Indication: 0
                    Date: 2021.06.07
                    Time: 17:46:19
             Freeze Frame:
                    Hex Value: 0x4400
                    Hex Value: 0x4306
                    Hex Value: 0x122E
                    Hex Value: 0x02B0
                    Hex Value: 0x00FF
Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
   Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
   Component: EPB Audi B8   H09 0100
   Revision: 00000003    Serial number: 00000000488796
   Shop #: WSC 00000 000 00000
   VCID: 345F25E59736C92B17-8060
1 Fault Found:
01316 - ABS Control Module
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 188
                    Mileage: 381541 km
                    Time Indication: 0
                    Date: 2021.06.07
                    Time: 17:46:19
             Freeze Frame:
                    Voltage: 14.30 V
                    Count: 62
                    Speed: 68.0 km/h
                    Hex Value: 0x0260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
« Poslednja izmena: Jun 09, 2021, 02:23:28 pre podne od strane talenat »
Van mreže dixon
  • Poruke: 317
Odg: Audi A4 2009 problem sa ABS i rucnom, gde li je problem?
« Odgovor #1 poslato: Jun 10, 2021, 01:08:28 posle podne »
Прекидач кочнице, сензор притиска кочнице, ABS модул или пумпа ABS, треба проверити редом шта је у проблему :) отерај код писменог мајстора па нек среди
