Autor Tema: DPF Golf 6  (Pročitano 3286 puta)
Van mreže PeTaR016
  • Poruke: 10
  • Lokacija: Leskovac
  • Auto: Volkswagen Golf Mk6
DPF Golf 6
« poslato: Septembar 07, 2020, 05:14:45 posle podne »
Ovako imam problem sa DPFom na svom golfu. DPF je fizicki prisutan, ali pokazuje nerealne cifre na dijagnostici (tipa sve 0). Na dijagnostici pise da je dpf regenerisao pre 12500km sto nije normalno.  Na tehnickom su mi rekli da zagadjuje okolinu vise od dozvoljenog. Da li da ocekujem da je dpf odstranjen iznutra i softverski ugasen ili sta? Da napomenem da auto ide normalno i lepo vuce. Jedino sto mu je potrosnja nesto veca, pogotovo sa klimom. Lambda sonda pokazuje vrednost od 0,503 sto znaci  da je smesa prebogata da li to ima veze sa dpfom i sta je najbolje resenje?
Hvala unapred.
UPDATE
Izvestaj sa dijagnostike (U leru)
17:33:17                               D I Z N E
  IDE00365-ENG99400   Injection amount deviation cylinder 1-FAC_CYL_BAL1 -0.2510 mg/stroke
  IDE00366-ENG101187   Injection amount deviation cylinder 2-FAC_CYL_BAL2 -0.4547 mg/stroke
  IDE00367-ENG101684   Injection amount deviation cylinder 3-FAC_CYL_BAL3 0.6850 mg/stroke
  IDE00368-ENG103465   Injection amount deviation cylinder 4-FAC_CYL_BAL4 0.0467 mg/stroke
  IDE03893-ENG101196   Injection valve 1: voltage-V_INJ_MAIN[0] 113.91 V
  IDE03894-ENG104143   Injection valve 2: voltage-V_INJ_MAIN[1] 114.14 V
  IDE03895-ENG101536   Injection valve 3: voltage-V_INJ_MAIN[2] 113.42 V
  IDE03896-ENG102925   Injection valve 4: voltage-V_INJ_MAIN[3] 114.63 V
17:39:04 DPF I LAMBDA SONDA
  IDE00427-ENG101722   Particle filter: difference pressure-DIP_PF 7.46 hPa
  IDE00430-ENG102682   Particle filter: field regeneration request status-STATE_RGN_PF 0
  IDE00433-ENG103279   Particle filter: oil ash volume-MASS_ASH_PF 0.0000000 g
  IDE00434-ENG102050   Particle filter: soot mass calculated-MASS_SOOT_SIM_PF 0.00 g
  IDE00435-ENG101197   Particle filter: soot mass measured-MASS_SOOT_PHY_PF 0.00 g
  IDE00436-ENG102397   Particle filter: kilometers since last regeneration-DIST_RGN 12485.7 km
  IDE00558   Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor) 0.503 Lambda / 0.000 V
  IDE01407-ENG100958   Particle filter: fuel consumption since last regeneration-FCO_SUM_RGN 655.35 l
  IDE04680-ENG99353   O2 sensor 1: bank 1: voltage raw value O2 signal-Lambda probe voltage: bank 1: probe 1 (broadband probe) 2.012 V
  IDE05665-ENG103851   Oxygen value calculated-LAMB_EXT_CLC_FIL 3.1445
« Poslednja izmena: Septembar 07, 2020, 06:06:16 posle podne od strane PeTaR016 »
Van mreže PeTaR016
  • Poruke: 10
Odg: DPF Golf 6
« Odgovor #1 poslato: Septembar 15, 2020, 05:27:54 posle podne »
bump prosla nedelja, zna li neko ? Da dodam da sam endoskopskom kamericom proverio i unutrasnjost dpf i potvrdio da je sace i dalje prisutno.  Takodje i ponovo sam odradio dijagnostiku i devijacija na 3 cilindru iznosi  oko 1,6 kada je motor na radnoj temperaturi, ostali cilindri idu u minus jel to problem?
