Autor Tema: Golf 3 klimatronic PROBLEM (izbacuje gresku)  (Pročitano 3437 puta)
Van mreže davor1983
  • Poruke: 14
  • Lokacija: bor
« poslato: Februar 28, 2017, 11:53:44 posle podne »
Imam problem sa klimom , climatronic bez ECON moda. Ovako , klima je normalno radila i odjednom pocela da brljavi. Napunjana je , kada ukljucim klimu na climatronic ocita temperaturu ali me reaguje brzina ventilatora kabine kao ni podesavanje gde da duva a ne ukljuucuje ni kompersor. Posle nekih 2/3 min tako izbaci na ekranu HE umesto temperature i onda radi sve normalno osim kompresora koji ne pali uopste. A ispravan je, svi senzori temperature su ispravni ... u cemu moze biti problem ?
Odg: Golf 3 klimatronic PROBLEM (izbacuje gresku)
« Odgovor #1 poslato: Mart 01, 2017, 07:33:07 posle podne »
Probaj da ukljucis dijagnostiku na climatronicu kad pritisnes i drzis istovremeno : ventilator minus + lice + plavo i trebalo bi da izbaci brojcani kod.
ima vise fora za ulazak:
Its "lower fan speed" + "face" + "blue"
recirc button and the up button
Well I found this on a VWVortex page but its slightly different on U.S. models...I think
1. System error
2. Actual value feeler virtually
3. Actual value interior feeler console
4. Actual value outside temperature - feeler wasserkasten
5. Actual value outside temperature - feeler bumper
6. Actual value blowing out feeler floor space
7. Actual value blowing out feeler man Anstroemer
8. Display check
9. Actual digital value acknowledging potentiometer temperature flap
10. Target digital value temperature flap
11. Actual digital value acknowledging potentiometer A/C flap
12. Target digital value A/C flap
13. Actual digital value acknowledging potentiometer Fuss/Def flap
14. Target digital value Fuss/Def flap
15. Actual digital value acknowledging potentiometer ram air flap
16. Target digital value ram air flap
17. Driving speed (km/h)
18. Actual value of the blower tension (volt)
19. Desired value of the blower tension (volt)
20. Actual value of the compressor/on-board tension (volt)
21. Number of low-voltage events
(not volatilely)
22. Switching status of the high pressure switch
23. Number of high pressure events (volatile)
24. Number of high pressure events (not volatile)
25. A/D value kickdown switch
26. A/D value hot light
27. Engine speed
28. Compressor number of revolutions
29. Coding
30. Software-Version
31. Software index
32. Potentiometer error counter temperature flap
33. Potentiometer error counter A/C flap
34. Potentiometer error counter Fuss/Def flap
35. Potentiometer error counter ram air flap
36. Temperature flap notice cold
37. Temperature flap notice warm
38. A/C flap notice closed
39. A/C flap notice opened
40. Fuss/Def flap notice Def
41. Fuss/Def flap notice foot
42. Ram air flap notice up
43. Ram air flap notice too
44. Operating cycle counter
45. Interior temperature counted (Ninc) dig
46. Outside temperature filtered (°C)
47. Outside temperature not filtered (°C)
48. ECOR
49. Coolant temperature
50. Service life in min
51. Engine temperature °C
52. Compressor switching off conditions
53. Announcement more actively el. Exits:
Compressor/circulating air valve/water valve
54. Rule index
55. Outside temperature °C
56. Interior feeler virtually °C
57. Interior feeler console °C
58. Temperature wasserkasten °C
59. Temperature bumper °C
60. Blowing out feeler floor space °C
61. Blowing out feeler man Anstroemer °C
62. Sun intensity W/m-1
63. Sun intensity filtered W/m-1
64. Delta exhaust rise
65. Delta A/C Klappenverschiebung
66. Time constant/1.6 seconds
67. Cold weather starting correction
68. Maximum correcting variable for i and p-portion
69. Actual value blowing out feeler foot (cnts)
70. Desired value blowing out feeler foot (cnts)
71. Deviation (Epsilon)
72. Portion (+ heat/- cool)
I jos jedna verzija:
1) System error
2) Value virtual temperature
3) Value inside temperature at the console
4) Value outside temperature water box
5) Value outside temperature bumper
6) Value blowout temperature feet space
7) Value blowout temperature dashboard
8) Display Check
9) actual value temperature flap
10) rated value temperature flap
11) actual value A/C flap
12) rated value A/C flap
13) actual value feet flap
14) rated value feet flap
15) actual value recirculating air flap
16) rated value recirculating air flap
17) driving speed
18) actual value fan voltage
19) rated value fan voltage
20) actual value on-board voltage
21) Amount of low voltage events
22) switch position high pressure switch
23) amount of volatile high pressure events
24) amount of non-volatile high pressure events
25) A/D Value kick-down
26) A/D Value heater light
27) rpms of the engine
28) rpms of the chiller
29) coding
30) software version
31) software index
32) error counter temperature flap
33) error counter A/C flap
34) error counter feet flap
35) error counter recirculating air flap
36) temperature flap cold
37) temperature flap warm
38) A/C-flap closed
39) A/C flap closed
40) feet flap endstop def
41) feet flap endstop feet
42) recirculating air flap endstop open
43) recirculating air flap endstop closed
44) counter driving cycle
  • Poruke: 2147
« Odgovor #2 poslato: Mart 01, 2017, 08:48:23 posle podne »
Mogu biti i osiguraci i releji klime.
