Autor Tema: Audi S5 Cabrio MTM Michelle edition  (Pročitano 14064 puta)
Van mreže Ivke
  • IvKe ZaJeBaNt
  • Poruke: 1263
  • Lokacija: Svilajnac
  • VW - Das Auto
« poslato: Novembar 14, 2009, 10:41:44 posle podne »
November 14, 2009
- 3.0 TFSI engine goes up to 430 bhp after MTM's power therapy
- Top speed of 285 kph for the classy sport wagon from Wettstetten
- Complete package with power enhancement, exhaust system, suspension kit, brakes and sport rims
The engine specialist MTM in Wettstetten proposes a considerable power enhancement for the new Audi S4 and the brand new Audi S5 Cabrio. Using its approved control device M-Cantronic, both cars, which are motorized by the 3.0 TFSI engine, become powerful sports cars with an incredible power reserve. The MTM S4 - which is declined in its Avant model - after its power therapy, stand as a real successor of the Audi RS4, and the current V8 of the RS4 is only 10 bhp more powerful than the MTM S4. Besides the engine control device M-Cantronic, MTM provides the series production car S4 with 4 rear pipes silencers with throttle valves. What results is 430 bhp (317 kW), 515 Nm of torque and an incredible 4.6 s from 0 to 100 kph (0-60 mph) with the 6 speeds manual gearbox. When a V-Cantronic is also implanted as well as the M-Cantronic, the normal 250 kph top speed reachs 285 kph.
The S4 is not the only model which is motorized with the 3.0 L engine and new compressor technology. The S5 Cabrio is also built with the factory-made engine. It is then logical that MTM modifies the S5 Cabrio which allows cruising around with a massive power reserve. The tuning specialists from MTM propose different stages of performances, starting with at 380 bhp (280 kW) and 480 Nm of torque, which means about 47 bhp more than the series model. Who wishes the complementary exhaust systems with throttle valves in 4 rear pipes optic (4 x 80 mm), has access to the ultimo stage of power enhancement of 430 bhp and 515 Nm.
So much power in the new MTM S4 Supercharged needs an important brake system, that the customers can of course find by MTM. With 380 x 34 mm disk brakes, drilled with 8-pistons calipers, the S4 decelerate much better. With body work, MTM trusts the series model. However, MTM puts new lowering springs which lower the car up to 40 mm on the front axe and up to 45 mm on the rear axe. To reach the perfection, the package includes 19" rims in the original Bimoto design with dimensions 255/35 ZR 19. Of course, the 20" rims are also available in option.
source : MTM Press
Odg: Audi S5 Cabrio MTM Michelle edition
« Odgovor #1 poslato: Novembar 19, 2009, 12:57:50 posle podne »
Nerealno kako izgleda aooooooooooooooooo  tapsac
Van mreže Acca
  • Poruke: 3775
  • Auto: passat b5,5>vw GOLF 5
« Odgovor #2 poslato: Decembar 26, 2010, 06:06:02 posle podne »
 bonk bonk bonk kako je do jaja
  champ1
