Autor Tema: mpg to l/100km Sharan  (Pročitano 4556 puta)
Van mreže Denis1997
  • Poruke: 16
  • Lokacija: Berane
  • Auto: Sharan
« poslato: Oktobar 07, 2014, 11:46:29 posle podne »
Poz svima, dali neko zna kako da na Saranu 2002 god promijenim na boardu da mi meri u litre a ne u mpg pomocu Delphi DS150 NEW VCI  dijagnostike :)
  • Poruke: 7080
Odg: mpg to l/100km Sharan
« Odgovor #1 poslato: Oktobar 07, 2014, 11:54:31 posle podne »
pa jesi pokusao kod nekog u servis ... da ti da savet ... ili obrati se prijatelju nasem Zrnojed , on ti je u Blizini i mozda ti da neki savet ...
Djuka vozi Sharana i on dosta to sam radi ..ali trenutno je kasno ... mozda sutra kad vidi ... pa ti odgovori ...
malo da sacekas ...  :26
Van mreže Denis1997
  • Poruke: 16
  • Lokacija: Berane
  • Auto: Sharan
« Odgovor #2 poslato: Oktobar 08, 2014, 12:48:40 posle podne »
Nasao sam nesto ovdje ali za VCDS dijagnostiku ali ona ne prihvata saran, a evo sta sam nasao:
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active
+08 = Seatbelt Warning active (NAR only)
+10 = Seatbelt Warning Driver & Passenger active (NAR only)
+16 = Secondary Display (Radio/Navigation) active
Look at the third digit in the coding (Market version):
1 - "EU" 24 hour clock (may result in odometer in km in 2002+ clusters)  Valjda ovo
2 - "USA" 12 hour clock
3 - "Canada" 12 hour clock (may result in odometer in km in 2002+ clusters)
"The third digit in the code is the country code. The codes are:
4 - "UK" 24 hour clock (should result in odometer in miles) i ovo
5 - Japan
6 - Saudi Arabia
7 - Australia
Look at the fourth digit in the coding (Cylinders):
3 - No Service Interval (2002+ models)
4 - 4-cylinder (1999-2001 models)
6 - 6-cylinder (1999-2001 models)
Look at the fifth digit in the coding (Distance impulse multiplier):
2 - 3538
4 - 3648 (some 2002+ models)
So, if you want to have Seatbelt warning and washer fluid warning only in a 2001 Canadian 6-cylinder vehicle, (add 00+02+04 = 06),3,6,2 = 06362.
E sad da nezna neko ove kodove za Delphi dijagnostiku mnogo bi mi znacilo :)
« Odgovor #3 poslato: Oktobar 08, 2014, 01:23:19 posle podne »
Nece svaku dijagnostiku da prihvati tako da ti je moj savet da odes negde do pismenog servisa da ti prebace to. A pretpostavljam da ti je sharan za Americko trziste .
« Poslednja izmena: Oktobar 08, 2014, 01:25:43 posle podne od strane RUS »
  • Poruke: 7080
« Odgovor #4 poslato: Oktobar 08, 2014, 04:30:00 posle podne »
pa pise ti da ne moze 2002 godina ...
a tvoj 2002 godiste ...
Ja mislim da ce to Djuka da ti resi samo da se konektuje , on sve sam na svom Sharanu to radi ... ili ovo sto RUS kaze ...  :26
Jer ti je istrument tabla u Miljama ili u Kilometrima ... mozda mora kompletan softver od Evropskog modela ...  :46
« Poslednja izmena: Oktobar 08, 2014, 04:32:09 posle podne od strane lolazoca »
Van mreže Denis1997
  • Poruke: 16
  • Lokacija: Berane
  • Auto: Sharan
« Odgovor #5 poslato: Oktobar 08, 2014, 04:46:40 posle podne »
E ovako tabla mi je u miljama skinuta je sa engleza, mijenjao sam tablu zbog boarda koi mi je brljavio nisam mogao nigdje da nadjem tablu sa ispravnim boardom, pa sam na kosovu nasao od engleza 2006god sa ispravnim boardom  i platio je 30e, a danas idem u servis da vidim sta moze da se odradi :)
  • Poruke: 7080
« Odgovor #6 poslato: Oktobar 08, 2014, 06:06:23 posle podne »
Fizicki je ista , ali parametri sa motornog kompijutera sigurno nisu ... zato tako i pokazuje ... moguce je da ima razlike izmedju 2002 i 2006 godista( dali su isti motori bili sa tvog i tog Engleza ) , i jos Englezi uvek zahtevaju nesto posebno u odnosu na ostala Evropska vozila ...
pisi sta si uradio ...  :26
P.S.
trebao si ovde pitati ...ima covek u Trsteniku samo Sharane rastura za delove i salje brzom postom ...  :46
« Odgovor #7 poslato: Oktobar 08, 2014, 06:29:17 posle podne »
Denise pođi kod Duška Popovića,ili kod Stankovića,makar majstora ima u Berane.
« Odgovor #8 poslato: Oktobar 08, 2014, 06:49:53 posle podne »
Nisam ni sumnjao u to. :46
  • Poruke: 7080
« Odgovor #9 poslato: Oktobar 08, 2014, 07:13:22 posle podne »
A dje si do sad bio Zrno ..mi se Odje ubismo da pomognemo a tebe nema ...  thumbup
Van mreže Denis1997
  • Poruke: 16
  • Lokacija: Berane
  • Auto: Sharan
« Odgovor #10 poslato: Oktobar 08, 2014, 10:42:17 posle podne »
Sto se table tice ona je od istog motora 1.9TDI 85kw AUY i perfektno radi samo ovo za milje, dans mi majstor nije bio tu pa sjutra cu sve da vidim i javljam :)
Van mreže zorancile
  • Poruke: 1273
  • Lokacija: Bašaid, VOJVODINA
  • Auto: golf 2 gtd
« Odgovor #11 poslato: Oktobar 08, 2014, 10:58:52 posle podne »
Ili da nadješ pumpu koja toči benzin u galonima. :)
Možda je neko i pumpu uvezao iz Engleske.
Van mreže Denis1997
  • Poruke: 16
  • Lokacija: Berane
  • Auto: Sharan
« Odgovor #12 poslato: Oktobar 10, 2014, 10:47:16 posle podne »
Problem rijesen pomocu orginalne VAG dijagnostike  :41 :41 :41 :41 hvala svima na pomoci
