Autor Tema: senzor diferencijalnog pritiska DPF...  (Pročitano 7271 puta)
Van mreže fric63
  • Poruke: 3
  • Auto: POLO2011
« poslato: Jun 24, 2014, 02:43:03 posle podne »
imal koja dobra dusa da podeli proceduru adaptacije ovog senzora...
neki majstori kazu nemora adaptacija samo se zameni i izbrise greska
drugi kazu mora adaptacija
auto vw polo 1.6 tdi 2011
poz
Odg: senzor diferencijalnog pritiska DPF...
« Odgovor #1 poslato: Jun 25, 2014, 06:34:06 pre podne »
Mora adaptacija, ja sam menja na mom Tigu... Mora biti original senzor i pozeljno je da se poklapaju brojevi na senzoru. Prvo ga zamenis, pa obrises greku, pa adaptiras.
Pomocu VCDS:
http://wiki.ross-tech.com/wiki/index.php/2.0L_CR_TDI
Exhaust Gas Differential Pressure Sensor (G450) Adaptation is performed using the Coding-II function in vehicles with a CAN Protocol EDC. UDS Protocol control modules do not support this method of G450 Adaptation and Basic Settings are used instead.
Instructions should be populated in a pop-up balloon when connected to the controller in question.
Key ON, Engine OFF
[Coding-2] or [Login-II] button
Enter the code shown in the VCDS pop-up balloon
[Do It!]
Switch Ignition OFF for 30 seconds
After the key is cycled back on the adaptation should be completed. If it is not completed, proceed with the next steps:
These steps must be repeated 5 times.
Ignition ON
Wait 5 seconds
Ignition OFF
Wait 40 seconds
Repeat 4 more times
Note: If a code is NOT shown in the VCDS pop-up balloon registered customers can Join our Forum -or- send the complete Auto-Scan via email with the recent repair history including the part number of the original/removed sensor and the new replacement sensor.
http://forums.ross-tech.com/showthread.php?703-Can-not-find-an-option-a-to-recalibrating-DPF-censors&highlight=G450+Adaptation
For some reason we get a lot of calls about incorrect replacement sensors sold to repair shops from the VW dealer so please make sure that BOTH sensors were NOT the same 076-906-051-A part number.
1K0-131-552-B is control line with pressure difference sender per PartsLink24 by VIN
03G-906-051-A is pressure difference sender per PartsLink24 and supersedes to 076-906-051-A as far as I can tell.
Based on the parts illustrations alone (I did not dig through the repair manual yet) it looks like the 1K0 sensor is the front/upstream G450 and the 076 sensor is the rear/downstream sensor which should be named G451. If you aren't sure please check the part numbers located on the old sensors and post the numbers here for review.
Exhaust Gas Differential Pressure Sensor (G450) Adaptation is performed as follows:
* Key ON, Engine OFF
* [Coding-2] or [Login-II] button
* Enter 30605 [Do It!]
* Switch Ignition OFF for 30 seconds
* Ignition ON
* Wait 5 seconds
* Ignition OFF
* Wait 40 seconds
* Repeat 4 more times
Van mreže fric63
  • Poruke: 3
  • Auto: POLO2011
« Odgovor #2 poslato: Jun 25, 2014, 11:25:07 pre podne »
e hvala , sutra mi stize senzor pa ce odradimo...
