Autor Tema: MK5 rcd 300 problem  (Pročitano 3749 puta)
Van mreže Leekrr
  • Poruke: 7
  • Auto: Golf 5
MK5 rcd 300 problem
« poslato: Jun 02, 2014, 02:24:48 pre podne »
Pozdrav svima
Zadnjih 3-4 dana desava mi se da se muzika sama upali. Uredno se ugasi kada ugasim auto i nista se ne desava narednih 10-15 min, ali posle nekoliko sati muzika se sama upali. Pokusao sam i da je ugasim na dugme pre nego sto ugasim auto, ista prica.
Jel ima neko neku ideju sta bi mogao da bude problem ?
Hvala unapred :)
Van mreže topmarko
  • Poruke: 2563
  • Firefighter K-540
  • Auto: golf
Odg: MK5 rcd 300 problem
« Odgovor #1 poslato: Jun 02, 2014, 11:14:01 posle podne »
This is the VW information on this problem.
 Technical product information Transaction No.: 2010658/9
 Radio RCD 300: radio sporadically switches itself on Release date: 09-Aug-2008
 Customer statement / workshop findings
 The radio RCD 300 switches itself on and runs for an hour. This can happen several times.
 Technical background
 Because of corrosion on a switching contact in the CD d rive, the d rive by mistake recognises the insertion of a CD.
 Production change
 Improved contacts from 02.2005.
 Measure
 Ask the customer to keep a CD in the radio. As a result, the switch contact stays permanently open and the radio doesn’t switch itself on any more.
 Warranty accounting instructions
Customer information
 Because of humidity and dirt the CD d rive recognises by mistake that a CD has been selected and switches the radio on. By leaving a CD in the d rive the unintentional switching on of the radio can be avoided.
Ovo sam nasao na nekom engleskom forumu,mozda pomogne
Morao sam da pisem d rive jer kad se spojeno napise to izgleda ovako drive  biggrin
« Poslednja izmena: Jun 02, 2014, 11:25:06 posle podne od strane topmarko »
Van mreže Leekrr
  • Poruke: 7
  • Auto: Golf 5
« Odgovor #2 poslato: Jun 02, 2014, 11:39:03 posle podne »
Hvala
Probacu , pa javljam da li je problem resen :)
Hvala jos jednom i pozz :)
Van mreže Leekrr
  • Poruke: 7
  • Auto: Golf 5
« Odgovor #3 poslato: Jun 03, 2014, 07:33:47 posle podne »
Disk ubacen , problem resen !!! case closed ;)
