VW - Forum
Održavanje i servisi
In Car Electronics (ICE)
(Urednici:
RUS
Lepi
Ubacivanje maglenki na passata b5.5
Stranice: [
Tema: Ubacivanje maglenki na passata b5.5 (Pročitano 1449 puta)
MarkoPodgorica
VW Početnik
Poruke: 48
Lokacija: Podgorica
Auto: Passat b5.5 2.8 4motion
poslato:
Novembar 25, 2013, 07:29:50 posle podne »
Zna li ko da mi kaze sta sve osim kupovine maglenki i prekidaca novog moram da uradim da bi to sve funkcionisalo..
Lepi
Moderator
Master Member
Poruke: 4778
Lokacija: Canada
Auto: Rabbit 2.5
Odg: Ubacivanje maglenki na passata b5.5
Odgovor #1 poslato:
Novembar 25, 2013, 09:54:34 posle podne »
Parts Required:
Euroswitch
Some wire taps, and butt connectors
Automotive wire (at least two colors)
3B7-941-699A (Left Fog Lamp)
3B7-941-700A (Right Fog Lamp)
3B0-853-665-L-B41 (Left Grill Piece)
3B0-853-666-L-B41 (Right Grill Piece)
N-013-957-1 (Oval Head Panel Screw) (6 required)
N-905-353-01 (Speed Nut) (6 required)
1J0-973-722 (Fog light connector Housing) (2 required)
000-979-133-A (Connectors for Housing) (2 required)
Note:
You will need a total of 4 connectors for the Fog Light housings. It has come to my attention that some places are either cutting the 000-979-133-A wires in half or VW has smartened up and they're only giving you one connector with this wire. So you get a wire with a metal connector on one end and then just cut off on the other. If this is the case you will need 4 of part 000-979-133-A.
Pre-2003 or non US Spec models may require:
12V 20Amp Relay
20Amp Inline Fuse
Poslednja izmena: Novembar 25, 2013, 09:56:22 posle podne od strane leponiko
Ivan
One & Only
Super Moderator
Ultimate Member
Poruke: 13943
Lokacija: Лазарев град
Odgovor #2 poslato:
Novembar 25, 2013, 10:44:30 posle podne »
Ili odi na otpad i skini sve sto ima veze sa maglenkama.
Taman ces da vidis gde, sta i kako ide.
Volkswagen Passat 32B by Ivan
Lepi
Moderator
Master Member
Poruke: 4778
Lokacija: Canada
Auto: Rabbit 2.5
Odgovor #3 poslato:
Novembar 25, 2013, 11:14:28 posle podne »
U pravu si kolega
Stranice: [
VW - Forum
(Urednici:
RUS
Lepi
