Autor Tema: Cemu sluzi relej 31 na Corradu?  (Pročitano 4932 puta)
Van mreže vladairon
  • Pure German style
  • Poruke: 2357
  • GERMAN CARS
« poslato: April 18, 2012, 08:50:45 posle podne »
Ljudi hitno mi treba ako zna neko cemu sluzi relej 31 na Corradu?
« Poslednja izmena: April 18, 2012, 08:52:27 posle podne od strane vladairon »
Call me a relic,
Call me what you will,
Say I'm old fashion,
Say I'm over the hill,
  • Poruke: 13937
Odg: Cemu sluzi relej 31 na Corradu?
« Odgovor #1 poslato: April 18, 2012, 09:05:42 posle podne »
Bolje daj onaj serijski broj od 9 brojeva.
  • Poruke: 10352
« Odgovor #2 poslato: April 18, 2012, 09:06:25 posle podne »
Neko je već postavio slično pitanje na jednom forumu,evo ti pa pogledaj malo,možda ti šta pomogne.
1 = carb inlet manifold heater
2 = fuel pump (MK1 & Early MK2/Rocco K-Jet, no rev limiter)
5 = shift light and MPG gauge
17 = x-over relief (disables most ign live items while engine turning on starter motor)
18 = x-over relief (disables most ign live items while engine turning on starter motor)
19 = front wiper intermittant
20 = rear wiper non-intermittant (when you push the stalk forward, it'll only wipe once, no intermittant!)
21 = hazard/indicator
23 = switched relay, often used for electric windows
24 = switched relay, often used for horn or fogs on older models
30 = MK3 (GTI 8v or 16v?) ECU
31 = 'time control unit' fan control (fan after run)
32 = MK2 digifant ECU
33 = headlight washers
36 = headlights on warning (possibly seatbelt too?)
42 = coolant level sensor control (pre-90 & digifiz dash)
43 = coolant level sensor control (pre-90 & digifiz dash)
53 = misc equipment ignition switched (horn, fogs, leccy windows etc)
57 = k-jet 8v idle speed control relay
61 = decelleration cut-off for carb models
62 = fuel pump (Later MK2/Rocco/Cabby K-Jet, built in rev limiter)
67 = fuel pump (MK2 digifant, 16v and MK3 models)
72 = rear wiper intermittant
79 = ABS system relay
80 = fuel pump (MK2 digifant, 16v and MK3 models)
83 = control unit for syncro freewheel lock
90 = fuel pump after run control unit
99 = front wiper variable intermittant
103= glow plug
104= glow plug
109= early VR6 ECU relay
133= aircon
147= aircon
150= starter motor
167= fuel pump (MK2 digifant, 16v and MK3 models)
174= rear wiper
179= ABS control unit relay
191= hazard/indicator
192= intermittant wash/wipe for models w/rain sensor
204= 40a, fog lamp, electric fan etc. pinout compatible to 53
213= fan, assume radiator?
370= fan, assume radiator?
372= fuel pump relay, 97-05 Passat
389= intermittant wash/wipe
407= rear petrol flap
409= fuel pump relay, 02 Golf
644= x-over relief (disables most ign live items while engine turning on starter motor)
« Poslednja izmena: April 18, 2012, 09:09:17 posle podne od strane Modus »
Van mreže vladairon
  • Pure German style
  • Poruke: 2357
  • GERMAN CARS
« Odgovor #3 poslato: April 18, 2012, 10:03:39 posle podne »
Ma ortaku treba za Corrado G60,treba mu da zna koji je od pumpe za gorivo?!!!Pa me pitao da nije ovaj 31.Hvala vam ortaci,kad mi bude javio koji je gledano po ovoj semi napisacu ovde  mahac!
Call me a relic,
  • Poruke: 13937
« Odgovor #4 poslato: April 18, 2012, 10:13:33 posle podne »
Broj 72 je za pumpu za gorivo.
Stoji na mestu broj 2.
Tu inace stoji i relej za grejace kod dizela i za grejac u usisnoj grani kod benzinaca.
Van mreže vladairon
  • Pure German style
  • Poruke: 2357
  • GERMAN CARS
« Odgovor #5 poslato: April 18, 2012, 10:30:27 posle podne »
Je l mozda siv  biggrin?Znaci gledano s leva na desno drugi?Hvala ti puno!!!
Call me a relic,
  • Poruke: 13937
« Odgovor #6 poslato: April 18, 2012, 10:32:18 posle podne »
Ne, crn.
U gornjem redu drugi sa leva.
Van mreže vladairon
  • Pure German style
  • Poruke: 2357
  • GERMAN CARS
« Odgovor #7 poslato: April 18, 2012, 10:44:33 posle podne »
Ok tnx  clap!
Call me a relic,
« Odgovor #8 poslato: April 19, 2012, 12:53:56 pre podne »
72 je rele zadnjeg brisaca/ Za pumpu stoji u donjem desnom uglu i ima oznaku 67 i 167 najcesce a nekad ide i 1 i jos jedan trocifreni, ne secam se tacnog broja.
  • Poruke: 13937
« Odgovor #9 poslato: April 19, 2012, 12:55:29 pre podne »
Onda table nisu iste.
Ta od njegovog auta i ova sto sam ja gledao.
« Odgovor #10 poslato: April 19, 2012, 01:07:03 pre podne »
Na njegovoj i tablama koje su NT stoji dole desno a 72 je za brisace, nema sanse da moze da posluzi necemu drugom.
Van mreže goran-ub
  • Poruke: 462
  • Lokacija: Ub
  • Auto: golf 2 gti 16v
« Odgovor #11 poslato: April 19, 2012, 08:08:35 posle podne »
31 ili 220 su isti releji i sluze da pale ventilator kada se ugasi auto ali za to treba da ima neki davac koji se recimo na 16v nalazi na poklopcu ventila,a za pumpu moze jos da bude i 67 plavi ili 61-65 oni su crni
