Autor Tema: Kataloski Brojevi Golf 4/Bora/Jetta/R32  (Pročitano 5620 puta)
Van mreže DuX
  • Poruke: 219
  • Lokacija: Sarajevo
  • Auto: VW Golf IV TDI
« poslato: Novembar 02, 2014, 01:13:45 posle podne »
Evo nekih kataloskih brojeva od Golf 4/Bora/Jetta/R32  biggrin vrjerujem da ce svima biti korisni..  tapsac
Aero Wiper Blades: Driver Side: 1J1 955 425
A Passenger Side: 1J1 955 426 A
 Blade Inserts: 1J0 955 429 A
Air (Box) Filter: 1J0 129 620
 Amp/Changer Trunk Trim: 1J6 867 427 AE 8JS
 Aristo Wheels: 1J0 601 025 BA 88Z
Armrest: Black Leather Lid: 3B0 867 173 KWL
 Black Armrest Body: 3B0 867 174 A94
Left Armrest Trim: 1J0 864 279 A 2QL
 Right Armrest Trim: 1J0 864 280 A 2QL
 Mounting Kit: 1J0 898 079
 Optional cup holder: ZVW 919 001
Aspherical Mirror Glass: Left: 1J1 857 521C
Right: 1J2 857 522C
 Badges & Nameplates:
 Chrome Rear VW logo: 1J6 853 630 B FCS
 Chrome Front VW logo: 1J0 853 601 FDY
 Black Rear VW logo: 1J6 853 630 A 041
 Black Front VW logo: 1J0 853 601 A 041
R32 rear nameplate: 1J0 853 675 Q 739
 R32 front nameplate: 1J6 853 679 D PWV
 Belly Pan/Dampener: (all plastic covers) Center: 1J0 825 237 P
 Left vertical for attachment to frame rail: 1J0 825 245 L
 Right vertical for attachment to frame rail: 1J0 825 250 K (V-belt cover)
 Bottom Bumper Left: 1J0 825 703
 Bottom Bumper Right: 1J0 825 704
 Bottom Bumper Center: 1J0 825 001
 Right front fender liner 1JO 809 962 F
 Left front fender liner 1JO 809 961 E
Brake Calipers: Front Left: 1J0 615 123 E
 Front Right: 1J0 615 124 E
 Rear Left: 1J0 615 423 F
 Rear Right: 1J0 615 424 G
 Brake Light Switch: 1C0 945 511 A NAR (RECALL)
 Brushed Aluminum Interior Trim Pieces
 Ashtray Cover: 1J1 857 351 B 4J4
Cupholder: 1J0 858 501 D 4J4
 Left vertical trim: 1J0 853 189 A 4J4
 Right vertical trim: 1J0 853 190 A B41
 Climatronic surround: 1J0 907 047 P 4J4
 Climatronic surround (alternate, black): 1J0 907 047 M01 C
 Passenger Side Pull Handle: 1J0 867 172 C NPX
 Passenger Side Door Handle: 3B1 837 114 T 4J4
 Driver Side Pull handle/switch housing: 1J3 867 171 A NPX
Driver Side Door handle: 3B1 837 113 L 4J4
 Bumpers:
 US Front Bumper Cover: 1J0 807 217 K GRU
 Euro Front Bumper Cover: 1J0 807 217 H GRU
 US Rear Bumper Cover: 1J6 807 421 L GRU
 Euro Rear Bumper Cover: 1J6 807 421 J GRU
 Bumper Torx Screw: N 907 750 01
Bumper Speed Nut: N 015 439 1
 Cabin
 (Pollen) Filter: 1J0 819 644
 CD Changer Mounting: Brackets, need 2: 1J0 035 234 A
 Screws, need 6: 000 051 750
 Center Console: Front: 1J1 863 201 E 2QL
 Tray behind coin slot: Insert: 1J0 858 373 C 2QL
 Pad: 1J0 863 328 C B41
 Center Console/Handbrake Screw Covers: 1J0 863 276 B 2QL
 Cluster (OE UK - 180 MPH) with full MFA/FIS: 1J0 920 946
 FX Cluster (OE EU - 300 Km/h) with full MFA/FIS: 1J0 920 846 FX
- 6 speed manual 1J0 920 846 GX
 - DSG Cluster Harness Locking Connectors: 1J0 972 977 C
 - Green, right side. 1J0 972 977 D Blue left side
  Control Arms:
 Left Front: 8N0 407 151 D
 Right Front: 8N0 407 152 D
 Cooling Fans: 290 mm - 1J0 959 455 R 345 mm - 1J0 959 455 S
 Dashboard (does not include cluster):
 1J1 857 002 E 84L
 Dead Pedal Base Clip: 1J1 864 777A B41
 Door Cards
, Front: Black w/ black leather: Left: 1J3 867 011 ED LKU
Right: 1J3 867 012 EN LKU
 Flannel grey w/ grey leather: Left: 1J3 867 011 EF LKX Right: 1J3 867 012 EQ LKX
 Black & light beige w/ beige leather: Left: 1J3 867 011 EF LKY Right: 1J3 867 012 EQ LKY
 Distance Pieces: These are the fender extensions that mate the fender liner to the R bumper
 Left: 1J0 806 569
 Right: 1J0 806 570
 Door Delocking Kit: Metal Housing: 1K4 839 167 Cap: 3B4 839 879 A GRU
 DSG Paddles (R32 OEM): Left: 1J0 951 527 4J4 Right: 1J0 951 528 4J4
 Endlinks: Front Left: 1J0 411 315 D Front Right: 1J0 411 316 D Rear (same for both sides): 1J0 505 466 B
 Engine Coolant: G 012 A8 FA4
Engine Cover: 022 103 925 AD
 Engine Cover (center strip): 022 103 935 AB
 Engine Cover Emblem (Blue & White version): 038 103 940 F
 Exhaust Flapper Solenoid: 1J0 906 283 C
 Final Drive: 02D 525 010 AE
 Front Upper Grille: Primered Grille: 1J0 853 653 C GRU
 Grille Backing/Frame: 1J0 853 655 G 01C
Chrome VW Logo: 1J0 853 601 FDY
 Front Lower Grilles: Center: 1J0 853 677 F B41 Left: 1J0 853 665 D B41 Right: 1J0 853 666 J B41
 Clips for center grille: N 104 910 01
 Fuel Door, Primered: 1J6 809 857 E GRU
Fuel Filter: 1J0 201 511 A
Green Top Coolant Sensor: Sensor: 059 919 501 A O Ring: N 903 168 02 Retaining Clip: 032 121 142
 Haldex Crush Gasket: 02D 525 589 Haldex Servicing: Fluid: G05 217 5A1 Filter: 02D 525 558 A
 Wrench: T 100 66 Headlight Mount Repair Kits: Left: 1J0 998 225 Right: 1J0 998 226
 Headlight Rear Covers: Low Beam Left: 1J1 941 607 F Low Beam Right: 1J1 941 608 F High Beam (Both Sides): 1J0 941 607 C
 Heat Shield Fasteners: N 019 538 2
 Hub Caps: OEM VW black/chrome: 1J0 601 171 BXF
 Ignition Coil: 022 905 715
 Interior Trim Panel Clip: 3B0 868 243
 License Plate Front Mounts: European Mount: 1J0 807 287 A
 US Mount: 1J0 807 287 D B41
 Mirror Motors (For Power Folding):
 Window Motor LHD, Driver Side: 1C0 959 801B 017
 Window Motor LHD, Passenger Side: 1C0 959 802C 017
 Mirror Switch: 1J1 959 565 E 01C - Satin black, includes push spot for folding.
 NGK Iridium Plugs: 101905606A
 Oil Filter: 071115562
Oil Filter Housing Cover: 071 115 433
 Oil Filter Housing Drain Plug: 071 115 434
 Oil Pan: 021103601L
 Oil Pan Drain Plug (w/ Washer): N 908 132 01
 Oil Pan Sealer: D 176 404 A2
 The old number, AMV 188 001 02, seems to be more appropriate for use with sealing the cam cover
. Oxygen Sensors (Lambda Probe):
Pre-cat, left: 022 906 262 R (Superseded by 079 906 262 F)
 Pre-cat, right: 022 906 262 BB
 Post-cat, left: 022 906 262 L
 Post-cat, right: 022 906 262 K
 Parktronic Senders: 1K0 054 630 A
 Phaeton Brake Cooling Kit
: Left Cooling Duct: 3D0 615 447D
 Right Cooling Duct: 3D0 615 448D
 Left Splash Shield: 3D0 615 311C
Right Splash Shield: 3D0 615 312C
 Radio Pockets, Single DIN:
 Upper Pocket: 1J0 857 058B 1QA
 Lower Pocket: 3B0 857 058 2AQ
 Rain Tray/Deflector: 1J1 819 415 B B41
 Rain Tray Rubber Seal: 1J0 823 723
 Rear Aero Wiper (from MkV platform):
 Arm: 6Q6 955 707 C
 Blade: 6Q6 955 425 A
 Cap: 6Q6 955 435
 B Rear Hatch (generic MkIV): 1J6 827 025 G
 Rear Headrests (black leather):
 Leather cover: 1J0 885 921 AT LGL
 Foam padding: 1J0 885 931 B
 Frame w/ attachment posts
: 1J0 885 914 B
 Rear Swaybar Clamp: 8A0-511-439
 Rear Wiper Blade (OEM US): 1J6 955 427
 Repair Wire: 000 979 133
 Roof Interior Rear Molding (black): 1J6 867 617 B 54A
 Rear Hatch Panels: Bottom: 1J6 863 459 E B41
 Glass Trim: 1J6 867 603 F B41
 Trunk Lid Trim: 1J6 867 601 F B41
 R-Line Items:
Accessory Pack: ZVW 355 018
 Center Caps: JNV 601 171 BXF
 Monster Mats (Front Only): ZVW 179 002 R
 Seats:
 Leather, Front: Right top: 1J0 881 806 LT LGL
 Left top: 1J0 882 805 GM LGL
 Right bottom: 1J0 881 406 G LGL
 Left bottom: 1J0 881 405 FD LGL
 Leather, Rear: Top left: 1J0 885 805 PN LGL
 Top right: 1J0 886 806 N LGL -> 1J0 886 806 B LGL
 Bottom left: 1J0 885 405 DN LGL
 Bottom right: 1J0 885 406 DC LGL
 Cloth, Front: Right top: 1J0 881 806 LS QZZ
 Left top: 1J0 882 805 GL QZZ
 Right bottom: 1J0 881 406 D QZZ
Left bottom: 1J0 881 405 ET QZZ
 Cloth, Rear: Top left: 1J0 885 805 QE QZZ
 Top right: 1J0 886 806 A QZZ
 Bottom left: 1J0 885 405 EF QZZ
 Bottom right: 1J0 885 406 DP QZZ
Sidemarker/Fender Repeater Bulbs: N 017 752 2
 Sideskirts: Left: 1J0 853 859 B GRU
 Right: 1J0 853 860 B GRU
 Spark Plugs: 101 905 606 A
 Steering Rack: 1J1 422 063 F
 Subframe Bolts: N-907-528-01 (need 2) N-907-349-01 (need 2)
 Sunglasses Holder: 1J0 857 465 Y20 (Beige only, must be painted)
 Sunroof Crank: 4B0 875 699
Sunvisors: Right: 3B0 857 552 AK 3H8 Left: 3B0 857 551 AK 3H8
 Bracket: 3B0 857 561 B B41
 Bracket cap: 3B0 857 563 B41
 Suspension Nuts & Bolts:
 Front: Sway Bar End Link (need 2): N 015 081 4
 Knuckle Bolt (need 2): N 102 078 03
 Knuckle Nut (need 2): N 101 064 02
 Rear: Control Arm Bolts: N 104 162 01
 Control Arm Nuts: N 101 064 02
 Lower Shock Bolt (need 2): N 104 281 01
 Upper Shock Bolt (need 2): N 907 813 01
 Taillights (US spec): Left: 1J6 945 095 AC
 Right: 1J6 945 096 AC
Throttle Body: 022 133 062 AA TMC
 Box (For use with Euro Cluster & OE navi): 3B0 919 894A TT
 Spare: Wheel: 1J0 601 027 M03 C
Tire (125/70/18): 1J0 601 324 RCO
 Valve Stem Caps: VW Blue: ZVW 355 005 B
Wheel Hub: 8N0 407 613 C
 Wheel Bearing (Kit): 8L0 498 625 A
 Wheel Liners: Left: 1JM 809 957
 Right: 1JM 809 958
 Wheel Liner & Fender Spacer: 1J0 810 949
Windshields/Windscreens: Front: 1J0 845 011 AD (does not include rain sensor)
 Rear: 1J6 845 051 F
 Windows:
 Door, left: 1J3 845 201
 H Door, right: 1J3 845 202 H
 Side, left: 1J6 845 041 D
 Side, right: 1J6 845 042 D
« Poslednja izmena: Novembar 02, 2014, 01:39:07 posle podne od strane DuX »
Automobili za utrke nisu ni lijepi ni ruzni. Postaju lijepi tek kada pocnu pobjedjivati.
