Autor Tema: Eror 17125...pomoc...  (Pročitano 2273 puta)
Van mreže jovke
  • Poruke: 16
  • Auto: Passat B5.5 TDi Tiptronik
« poslato: Mart 12, 2013, 10:53:34 pre podne »
pre nekoliko dana mi je izbacilo na gresku DTS found 17125...
Torque Converter Clutch: Stuck Off/ No Power being transferred
da li je neko imao slicno "iskustvo" sa ovim...
Odg: Eror 17125...pomoc...
« Odgovor #1 poslato: Mart 12, 2013, 11:08:08 pre podne »
Pa piše ti. Konvertor obrtnog momenta,tj kvačilo se zaglavilo/snaga se ne prenosi na menjač.
Čisto sumnjam da će ti ođe bilo šta pomoći. Kod provjerenog majstora,na dijagnozu,da vidiš tačno šta se dešava. ;)
« Poslednja izmena: Mart 12, 2013, 11:10:39 pre podne od strane Zrnojed »
Van mreže Shomi
  • Poruke: 1738
  • Auto: Vozim shta stignem ;)
« Odgovor #2 poslato: Mart 12, 2013, 11:48:42 pre podne »
ross kaze
17125/P0741/001857 - Torque Converter Clutch: Stuck OFF / No Power being transferred
Possible Causes
Automatic Transmission Fluid (ATF) Level not OK
Transmission Sealing faulty
Automatic Transmission Fluid (ATF) dirty
Torque Converter faulty or incorrect Torque Converter installed
Solenoid Valve 7 (N94)/Pressure Regulating Valve 4 (N218) faulty
Torque Converter Pressure Valve faulty
Valve for Torque Converter Clutch faulty
Torque Converter Lock-Up Clutch faulty/worn our
Possible Solutions
Check Automatic Transmission Fluid (ATF) Level
Check Transmission Sealing
Check Torque Converter
Check Solenoid Valve 7 (N94)/Pressure Regulating Valve 4 (N218)
Check Torque Converter Pressure Valve
Check Valve for Torque Converter Clutch
Check Torque Converter Lock-Up Clutch
Special Notes
When found in VW Passat (3B): 5-Speed Automatic Transmission (01V), check Transmission Sealing (see TPL 2009761).
The NAR (North American Region) TSB 01-07-22 or 2011908 should contain similar information about the internal torque converter seal failure.
Sve u svemu, teshko da ces sam uspeti neshto da reshish... Pravac valjani majstor...
« Odgovor #3 poslato: Mart 12, 2013, 07:48:02 posle podne »
Evo i prevoda ;)
Mogući uzroci
Ulje za Automatske menjače (ATF ) Nivo nije OK
Dihtung neispravan
Ulje za Automatske menjače ( ATF) prljavo
Pretvarača obrtnog momenta neispravan ili netačni Pretvarač obrtnog momenta instaliran
Elektromagnetni ventil 7 ( N94 ) / Pritisak regulacioni ventil Pritiska 4 ( N218 ) neispravan
Ventil pritiska Pretvarača obrtnog momenta neispravan
Ventil za Torkue Converter kvačila neispravna
Pretvarača obrtnog momenta Lock- up kvačila neispravan / nose naše
