Autor Tema: Kupovina automobila - saveti, iskustva, preporuke...  (Pročitano 1364089 puta)
  • Poruke: 2147
« Odgovor #6180 poslato: Septembar 20, 2021, 10:16:17 pre podne »
Što se tiče bezbednosti struka je jasno rekla da samo ko sedi visoko je zaštićen. Nema tu dalje rasprave, 21. vek, novel tehnologije, nauka i tako to.
« Odgovor #6181 poslato: Septembar 20, 2021, 10:29:45 pre podne »
Платформа је MQB [emoji4]
Platforma je ista, razlika u klirensu je 5.8cm a u visini 26.6cm. Odakle izadje tih 20.8cm? A da, to je taj subjektivni osecaj sigurnosti.
Van mreže jerotije318
  • Poruke: 788
  • Auto: Pasat b5.5
« Odgovor #6182 poslato: Septembar 20, 2021, 11:08:45 pre podne »
Au kako crnite :huh:
Ko vozi normalno po propisima nece ni sa jednim autom imati problem, ne slutite pre kupovine na nesrecu.
Mislim da potrosnja i registracija igraju vazniju ulogu [i potreba za 4x4].
Ili covek mozda hoce da divlja sa kolima pa da se unapred pripremi....
Samo VW
« Odgovor #6183 poslato: Septembar 20, 2021, 12:39:25 posle podne »
Raco, daj neku studiju te struke? Nije isto sedeti visoko u kamionu i u Daciji Duster. :)
https://www.smflegal.com/2021/06/01/suvs-are-more-dangerous-than-we-think/
https://felixgonzalezlaw.com/blog/are-suvs-safer-than-cars/
https://www.accessmagazine.org/fall-2002/suvs-really-safer-cars/
Da citiriram samo par delova iz ovih tekstova:
" The risk to drivers of average midsize and large cars is about the same as for the average SUV. The risks differ in their makeup, with a higher fraction of fatalities in SUVs from rollovers. Similarly, the risk to drivers of the safest midsize and large car models (Avalon, Camry, and Accord) is about the same as for the safest SUVs (Suburban, Cherokee, and Tahoe). However, the average SUV poses nearly twice the risk to drivers of other vehicles as do the average midsize and large cars. The net result is that the combined risk of the average SUV (129) is about 25 to 30 percent higher than that of the average midsize (105) or large car (100"
"They can lull SUV drivers into a false sense of security, resulting in greater risk-taking.
They may be exempt from certain safety standards that apply to passenger cars.
SUVs are more likely to kill or seriously injured pedestrians according to AARP, because they have larger blind spots, and because the point of impact in a collision is different than it would be in a sedan or smaller car.
The increased height still doesn’t eliminate the dangers of blind spots."
Ima tu mnoooogo faktora kad je u pitanju bezbednost, daleko od toga da visina znaci bezbednost i tacka. Ovi novi mali SUV-ovi koje vidjamo po ulicama sve cesce su takav marketinski trik, kod njih visina predstavlja prednost samo sto se tice preglednosti napred i cinjenice da cete lakse da se parkirate po neravnom terenu, preko viseg ivicnjaka itd. Mada iskreno ovo poslednje se uglavnom zloupotrebljava tako sto ljudi parkiraju kola gde je zabranjeno, po zelenoj povrsini i sl.
Eventualno moze znaciti  ljudima koji imaju probleme sa ledjima, pa im je lakse da udju u visi auto, ali sam ubedjen da jako mali procenat ljudi kupuje zbog toga.
« Odgovor #6184 poslato: Septembar 20, 2021, 01:36:47 posle podne »
Zbog cega trazi "bezbedan", visok, tezak auto sa pogonom 4x4 ako ce da vozi normalno?
Medisone, Raca se zajebava
  • Poruke: 788
  • Auto: Pasat b5.5
« Odgovor #6185 poslato: Septembar 20, 2021, 10:42:35 posle podne »
Hvala,
to sam pitao ali niko da prokomentarise :rolleyes:
Samo VW
  • Poruke: 2147
« Odgovor #6186 poslato: Septembar 21, 2021, 11:47:41 pre podne »
Madisone, niko nije rekao da je neko ko visoko sedi 100% zaštićen od prevrtanja.
Suština je da ako visoko sediš blaže prođe to prevrtanje, sa manje posledica.
Pusti ti šta ovaj Desmo priča, on je stari niskosedač i ne veruje u nauku i 21. vek.
« Odgovor #6187 poslato: Septembar 22, 2021, 01:34:30 posle podne »
B7 vrh auto, ja prezadovoljan. Ako bih ga menjao, samo B8. Toliko sam oduševljen. A možete naći na forumu daaaavno kad sam rekao da nikad ne bih vozio toliko veliki auto... dok nisam seo u B7.
SUV vozila nisu uopšte bezbedna. Većina ih kupuje jer misle da su bezbedni da će da zgaze ostale koji nisu SUV, ali tačka težišta vozila je dosta viša i prilikom manevra severnog losa (levo desno levo), to vozilo ima velike šanse da se prevrne. Jedna moja poznanica je imala udes u Beogradu pre nekoliko godina, pokušala da izbegne vozilo koje je stajalo u njenoj traci, smotala u stranu instiktivno da izbegne prepreku, zakačila vozilo, X3 BMW na krov i totalka. Ona se izlomila cela.
Dakle ako udaraš u nešto direktno, da SUV je bolji izbor. Međutim ako reaguješ da izbegneš prepreku (što je očeivana ljudska reakcija) i nemaš strahovite veštine da održiš vozilo na putu onda je SUV nebezbedniji.
Mišljenja sam da je bolje biti okružen vazdušnim jastucima u tom slučaju nego da se prevrćeš po vozilu.
« Odgovor #6188 poslato: Septembar 22, 2021, 01:57:11 posle podne »
Ja bi od-savetovao hibride jer imaš 2 motora o kojima moraš da vodiš računa na ovaj ili onaj način a glavna i skoro jedina prava svha je da obore potrošnju celom brandu za neki procenat zbog načina na koji se izvode testovi.
potrošnja je ta deklarisana prvih 100km koliko je test, i posle toga skače dosta iznad iste za taj auto jer vučeš sa sobom i mrtav teret baterije i el. motora.
izuzetak je ako imaš neke do jaja povlastice kupovinom istoga, tipa ne plaćaš porez, carinu, možeš da furaš po pešačkim zonama (kao po firenci taksisti recimo) itd itd. inače potencijalna ušteda u gorivu nema šanse da ti se vrati u nekom razumnom roku.
baterija košta otprilike 200e po kwh nevezano za sam auto (lakša računica odokativno), tako da za 8.8kw bateriju računaj cca 1800e za novu bateriju. nemaš tu šta da repariraš sem u domaćoj radinosti ćelije da se prepakuju,a takve koji to znaju možeš na ovom delu balkana na prste da nabrojiš.
za te pare ti je po mom skromnom mišljenju bolje da uzmeš ili A. klasičan auto + el. bicikl/trotinet B. full električan auto (vw up recimo), naravno u zavisnosti od toga šta uglavnom voziš.
S tim da o el. motoru gotovo da ne moraš da brineš tj nema održavanja.
Baterija uz pravilno korištenje ima 160.000km garanciju. Deluje mi više nego dovoljno za nekoliko vlasnika koji će da se izmene.
Baterija ima istu težinu puna ili prazna i računa se u ukupnu masu vozila koja je na testu.
U ovom trenutku kada nema mnogo el. punjača i samo punjenje relativno dugo traje u slučaju dužih putovanja, hibrid mi deluje kao odličan izbor. Onog trenutka kada se punjenje strujom dovede na razuman nivo, a već imamo nove modele sa 35 milja po minuti punjenje i kad infrastruktura to bude ispratila, a moraće zbog kamiona koji su sledeći na spisku, tada će hibridi biti prevaziđeni.
Van mreže Guarana
  • Poruke: 3473
  • Lokacija: Ljubljana
  • Auto: Toyota
« Odgovor #6189 poslato: Septembar 22, 2021, 09:02:35 posle podne »
Baterija radi po ciklusima, ne kilometrima i što je manja će ofc češće da se puni/prazni.
Oko težine hoću da kažem da imaš 300kg dodatne težine koji ti vrede 100km u najboljem slučaju i posle toga je balast običan dok ne staneš da puniš. To mi nekako ne deluje praktično sem ako ti je 90% vožnje u okviru tih 100km i imaš priilku da ga puniš gajbi.
Kod dužih putovanja ti je običan auto definitivno bolja opcija nego hibrid jer prosto nemaš nikakve koristi od električnog dela. Za isključivo EV u ovom delu već ima dovoljno mreže da ne moraš preterano da mozgaš dal ćeš imati gde da puniš itd. Jeste istina da nisu još uvek za dalja putovanja, tipa 500km+ , ali recimo meni bi pokrivao noviji EV 99% vožnje bez ikakvih problema.
Van mreže đunta
  • Poruke: 16
  • Lokacija: singidunum
  • Auto: golf 4 1.9 tdi 90
« Odgovor #6190 poslato: Septembar 22, 2021, 09:59:41 posle podne »
Nisam čitao forum pa se izvinjavam, da li bi neko mogao reći kakva je razlika u agregatima u tehničkom smislu između 90 konja i 105 konja, Golfa 1.9 TDI i da li se devedesetica može softverski pretvoriti u jači model, prolčitao sam da je osim pritiska u turbini, kod 90 konja je jednostavnija, ali ne znam šta to tačno znači praktično, hvala.
Van mreže Vwasil
  • Poruke: 941
  • Lokacija: CG
  • Auto: Volkswagen
« Odgovor #6191 poslato: Septembar 22, 2021, 10:51:02 posle podne »
Mislim da je kod 90 konja turbina manja i bez geometrije. Ali svakako postoji i razlike u mehaničkom dijelu, tu su druge oznake motora, predpostavljam i drugačije dizne.
« Odgovor #6192 poslato: Septembar 23, 2021, 01:20:41 pre podne »
Koji golf?
Van mreže đunta
  • Poruke: 16
« Odgovor #6193 poslato: Septembar 23, 2021, 09:08:32 pre podne »
Golf 5 1.9TDI, on ima dva tipa agregata u toj radnoj zapremini, od 90 i 105 konja, Golf 4 u 1.9 TDI ima 90, pored ostalih, ali nije PD motor a kod petice dizel  su svi Pumpa Dizna.
Van mreže iwcham1979
  • Poruke: 2224
« Odgovor #6194 poslato: Septembar 24, 2021, 09:35:41 pre podne »
Drugari jel ima neko ideju koliko bi kostali troskovi uvoza za ovo:
Ponudio bi mu 7k evra. Znam, nisam normalan [emoji23]
https://youtu.be/vupYyrdEFsk Auto pise da je u Spaniji. Ima ga na mobile.de. Trazi 8500e ali je spreman da se urazumi malo....
Sent from my iPad using Tapatalk Pro
Van mreže AcoVW
  • Poruke: 1766
« Odgovor #6195 poslato: Septembar 24, 2021, 06:31:37 posle podne »
Da nisi postavio pogresan yt link?
  • Poruke: 2224
« Odgovor #6196 poslato: Septembar 24, 2021, 10:07:02 posle podne »
To je taj [emoji41]
« Odgovor #6197 poslato: Septembar 24, 2021, 11:22:19 posle podne »
Drugar prodaje odlican allroad, 290.000km, 3500€
2.5 auto
  • Poruke: 2224
« Odgovor #6198 poslato: Septembar 24, 2021, 11:41:26 posle podne »
Nema ga na oglasima?
« Odgovor #6199 poslato: Septembar 25, 2021, 12:04:45 pre podne »
Bio je jedno vreme al trenutno ga nema, okacicu sutra slike pa ako te interesuje javi se
