Autor Tema: Brojevi na relejima  (Pročitano 9244 puta)
  • Poruke: 13938
Brojevi na relejima
« poslato: Novembar 10, 2010, 11:57:37 posle podne »
Da li moze neko da mi kaze zasta sluze releji sa sledecim brojevima na sebi:
18
21
43
60
Van mreže Dynamite
  • Poruke: 176
  • Lokacija: Cetinje
Odg: Brojevi na relejima
« Odgovor #1 poslato: Novembar 11, 2010, 08:44:23 pre podne »
21 ti je od zmigavaca
  • Poruke: 13938
« Odgovor #2 poslato: Novembar 11, 2010, 03:26:15 posle podne »
Mora da je od nekog mladjeg VW. Kod mene je relej za zmigavce velicine kao i onaj za brisace a ovaj je manji.
« Odgovor #3 poslato: Novembar 16, 2010, 11:34:45 pre podne »
Evo nekih primera, nemora uvek da bude tako....
1 = Carb inlet manifold heater relay
2 = Fuel pump relay (MK1 & Early MK2/Rocco K-Jet)
5 = Shift light and MPG gauge
15 = radiator fan
17 = x-over relay, 40amp?
18 = x-over relay
18 = relief relay for x contact
19 = int wash wipe relay(front)
19 = front wiper intermittant relay
20 = rear wiper non-intermittant relay (when you push the stalk forward, it'll only wipe once, no intermittant!)
21 = hazard/indicator relay
21 = turn signal flasheror trailer towing warning relay
24 = cont unit for coolant storage indicator
30 = MK3 (GTI 8v or 16v?) ECU relay
32 = MK2 digifant ECU relay
36 = seatbelt warning relay (possibly headlight warning too?)
43 = control unit for idle increase
53 = misc equipment ignition switched relay (horn, fogs, leccy windows etc)
53 = duel tone horn relay
67 = MK2 16v/ MK3 VR6 fuel pump relay
72 = rear window wipe relay
72 = rear wiper intermittant relay
74 = carb decelleration cut-off
80 = MK2 digifant fuel pump relay
99 = front wiper variable intermittant relay
109= VR6 ECU relay
133= aircon relay
167= MK3 & MK2 16v fuel pump relay
Van mreže mrki.ru
  • Poruke: 73
  • Lokacija: Ruma
  • Moja malenkost
  • Auto: Golf mk2 1.8
« Odgovor #4 poslato: Novembar 16, 2010, 10:28:30 posle podne »
Da li neko ima da proda(nabavi) rele 65,golf mk2 1.8 8v,u pitanu je rele pumpe za gorivo.??
Zivot je 1
Ali GTI je 1.8 :-)
« Odgovor #5 poslato: Novembar 16, 2010, 10:47:22 posle podne »
vidicu sutra mozda ja imam
Van mreže Jetta Ivan
  • Poruke: 1039
  • Lokacija: UB
« Odgovor #6 poslato: Novembar 16, 2010, 11:22:51 posle podne »
Imam ja Relej pumpe za  gorivo ti je 67 a ne 65 bar je kod mene tako.... :rolleyes:
Samo gas GTI je spas !!!!
« Odgovor #7 poslato: Novembar 17, 2010, 08:44:57 pre podne »
I u listi koju sam postavio je 67
Van mreže D@rko
  • Poruke: 1359
  • Lokacija: okolina Sapca
  • biker for life!
« Odgovor #8 poslato: Januar 17, 2011, 06:12:22 posle podne »
Relej na trojci... Na njemu pise 443 937 105 A. Zna li neko cemu on sluzi?
